I run an external 4 ch mixer with my dj i/o. I now have a Hercules mk2 controller. I want to control the vdj pro with the controller and have it send out through the dj i/o to the external mixer for cuing. In my config I do not see an option to run both dj io and controller. Its either 1 or the other. How is this done? Is it even possible?
geposted Wed 31 Jul 13 @ 1:08 pm
The Hercules will be listed under the mapping tab of the config page, whereas the DJIO will be listed under Sound Setup.
OK the Hercules will also be listed under Sound Setup because it has built in audio, but if you only want to use it as a controller, then as above - select the DJIO under Sound Setup. The Hercules should be set as the default controller anyway, if that's what you have plugged in.
If you have VDJ Pro then you should register the serial number to your account so you can download updates.
geposted Wed 31 Jul 13 @ 3:00 pm
Which Version of VDj do you use exaclty. See under Config/ Info.
If you use a old version, this could cause problems too.
geposted Mon 05 Aug 13 @ 2:15 am
