When I load a track into player A, it also puts the track into sidelist.
Not sure if it is supposed to act like this or not. Happens every time.
Thanks!
Thanks!
geposted Sat 03 Aug 13 @ 9:42 am
Normaly it put it there if you did NOT play it. You can deactivate this in the CONFIG / OPTIONS / AUTOSAFE (3 point from bottom on the right side)
Greets, Heiko
Greets, Heiko
geposted Sat 03 Aug 13 @ 10:00 am
Only on A?
How are you loading it? Dragging, keyboard, controller?
geposted Sat 03 Aug 13 @ 10:01 am
Yes, just dragging it and yes, only when I add a track to player A
geposted Sat 03 Aug 13 @ 10:56 am
OK I just tried this...
As Heiko says, a track only appears in the sidelist if it's already loaded to the deck and I then load another to the same deck without playing the first one.
Where are you dragging the track from? The VDJ browser, or somewhere else?
Is there anything loaded on the deck before you drag the track to it?
What skin are you using? I don't know if it matters, but just to be certain.
geposted Sat 03 Aug 13 @ 12:34 pm
What skin are you using? A badly made one an exhibit all sorts of oddities.
geposted Sat 03 Aug 13 @ 4:17 pm
Nothing from Virtual DJ on this? Wow...
Perhaps it can be fixed in VDJ8. (I hope I am still in business when that is released - over two years since it was announced)
geposted Mon 05 Aug 13 @ 7:47 pm
this has happened to me as well... using original skin, dragging with mouse and with cdj controller.
iv noticed that songs do appear in side list but never thought of it as a bug. i dont think it is a bug, ay.
geposted Mon 05 Aug 13 @ 10:06 pm
Can not duplicate. Did you disable "AutoSave Unplayed" in options? The first reply was from VDJ. They treat everyone the same, or did you require more stars to be satisfied?
geposted Mon 05 Aug 13 @ 11:13 pm
And I replied to his post...
geposted Tue 06 Aug 13 @ 11:05 am
You've not answered any of the questions that various people have asked you though...
geposted Tue 06 Aug 13 @ 12:01 pm
If a guy from VDJ answers you in 18 minutes, what was the purpose of this post? Have you tried any of the suggestions offered so far?
geposted Tue 06 Aug 13 @ 12:21 pm
Maybe this will help :)
Please answer the following questions -
geposted Tue 06 Aug 13 @ 1:08 pm
looks like he went out of business :-)
geposted Tue 06 Aug 13 @ 11:28 pm
...or he realised it was his goof and had a facepalm moment.
geposted Wed 07 Aug 13 @ 1:54 pm
He should still answer, so others may benefit, or we can offer assistance.
geposted Wed 07 Aug 13 @ 2:01 pm
