hello everyone,
i have a problem. i currently use pioneer wego and vdj LE, the wego has 4 hot cue buttons, so i can have 4 cues per song. if i try to get a new (fifth cue) it justs overwrites the one selected before. i heard i can have unlimited cue points, how can i do this? thank you.
geposted Sun 04 Aug 13 @ 4:58 am
VirtualDJ supports upto 99 cue points, but VirtualDJ LE is limited software and the number that you can access depends on the number of hot cue buttons the controller has.
However, if you upgrade to the full VirtualDJ Pro at a discount then you could map other buttons that you don't need/use to be additional cue points (E.g: hot_cue 5) or you can map keyboard shortcuts to do this and/or use a custom skin that has more than 4 cue points (This will allow you to access them using your mouse.)
geposted Sun 04 Aug 13 @ 11:27 am
