My main gig computer has become very unreliable time to upgrade.
I need a 32bit machine compatible with my controller and delta sound cards (support xp)
this is in auction closing shortly, and looks ok to me but your advice appreciated.
"Custom Built Gaming Machine "
CPU speed:
2.4 GHz
Cores:
4
Memory:
4 MB
Hard drive:
500 MB
CD / DVD:
CD + DVD writer
Specs:
Motherboard : MSI DKA790GX 7550
Processor: AMD Phenom 9750 Quad Core 2.4 GHz
Graphics Card: NVIDIA Geforce 9800GT 1GB (2 x Digital out, 1 x S-Video)
Onboard Graphics: 1 x DSUB 1 x Digital
HD Audio: Realtek - (Front) Mic in, Headphone out (Rear) Mic, L out, L in, SS out, CS out, RS out
RAM 4 Slots: 2 x Kingston 2GB DDR2 800 (4GB can take up to 8GB)
HDD Western Digital 500GB Sata
Card Reader: CF, MS, SD, XD/SM
Network Card: Realtek Gigabit
DVD +R RW DL
USB 2.0: Front x3 Rear x6
1 x eSata
1x S/PDIF (Optical)
1x HDMI
XP Professional (Installed OS)
CPU speed:
2.4 GHz
Cores:
4
Memory:
4 MB
Hard drive:
500 MB
CD / DVD:
CD + DVD writer
Specs:
DVD +R RW DL
1 x eSata
1x S/PDIF (Optical)
1x HDMI
geposted Sun 04 Aug 13 @ 11:06 pm
I'm sorry, but at this date, I would not advise getting an XP machine, unless it was a steal. How much is it.
geposted Sun 04 Aug 13 @ 11:51 pm
around $500 dollars need it to work with dmc2 controller, checked dalta cards should work
geposted Sun 04 Aug 13 @ 11:53 pm
is it possible that new vdj versions may not support xp
I think this computer will run windows will run windows 7 mb only coame out in 2008 and is 64 bit capabile
geposted Sun 04 Aug 13 @ 11:55 pm
My best friend uses the DMC 2 with Win 7, and I have 2 but just have not used in a while. I keep one in the van as a backup unit. I think $500 is way too much for an XP machine. TigerDirect just ran a week long sale on laptops, and you could have done a lot better. Besides, is this on ebay or something? How do you know if it will even do what you need. What looks good on paper, may not measure up in real life, then what are your options?
geposted Mon 05 Aug 13 @ 12:05 am
its New Zealand trademe ebay not big over here,
my dmc2 does not work on Win8 ....thought it was xp only
well found delta works on windows 7 maybe that's the way to go
geposted Mon 05 Aug 13 @ 12:10 am
I have a DMC2 working fine on a 64 bit Win7 Machine. Has been for nearly two years with no problems :-)
Only thing with newer Mother Boards is to check that the sockets PCI and so on are compatible with your sound cards. Having said that the Realtek on board sound cards work ok with VDJ, perhaps not the latest in quality but fine for most applications.
Daz
Daz
geposted Mon 05 Aug 13 @ 1:19 am
I just purchased this system so hoping its going to do the trick, thanks for all your advice
i'll let you all know how in performs;)
CORE i5/i7 NEW HIGH END COMPONETS
Gigabyte GA-Z68X Motherboard with USB 3.0
Core i5/i7 1055 motherboard
CPU speed: 6 GHz New
Cores: 2
INTEL PENTIUM 1055 G2020 CPU 6 Ghz of processing power 2 CORES 4 THREADS BETTER AND FASTER THAN MOST 775 QUAD CORES
Memory: 8 GB
New Corsair 2 x 4 gigs of ddr3 ram 2 slots spare
ATI HD3870 graphics card 512MB DDR3
Hard drive: 750 GB
Seagate Barracuda 750 gig hard drive
CD / DVD: CD + DVD writer
Quick and Powerful
Immaculate condition
Solid Build
You won't see a better bargain than this.
Absolutely Genuine Windows 7 Ultimate 64 Bit edition Service pack 1 fully activated and fully updated from Microsoft
Microsoft wireless keyboard and Optical mouse.
I WILL GARANTEE FOR 1 YEAR AND FIX ANY ISSUES FOR FREE.
REMEMBER I WILL NOT RIP YOU OFF. CHECK MY FEEDBACK 100% AFTER OVER 600 TRADES!!
I STAND BY MY TRADES IN EVERYWAY. BEWARE OF THE TRADERS WHO DON'T HAVE A GOOD RECORD
Cores: 2
Memory: 8 GB
Hard drive: 750 GB
Quick and Powerful
Solid Build
geposted Mon 05 Aug 13 @ 5:06 am
That spec doesn't make much sense to me...
Looks like they've just slapped a load of random jargon together to make it sound impressive.
They say it's a i5/i7 motherboard, but 1055 is an AMD CPU.
Intel Pentium are only a two star CPU, below even the i3 CPU.
And 6GHz???? I seriously doubt it!
geposted Mon 05 Aug 13 @ 9:41 am
You're right... doesn't make any sense whatsoever. Is this a lappy or a PC?
Put the ebay link up here so we can review.
Cheers,
Roy
Cheers,
Roy
geposted Mon 05 Aug 13 @ 12:23 pm
Yeah this is a desktop, very likely with a Intel® Pentium® Processor G2020 (3M Cache, 2.90 GHz), which has two cores, together 5,8 Ghz of 'processing power' .... If indeed to be trusted..
But ehm.. I suggest buying in a store or online shop close by..
geposted Mon 05 Aug 13 @ 6:11 pm
Never get an AMD Processor you will suffer badly.....
geposted Mon 05 Aug 13 @ 6:45 pm
Link is below yes its a desktop, which I like ..... and the 1055 should be a 1155 referring to the socket.
The Processor currently 2.9Ghz x2 which is where the 6Ghz comes from and can be upgraded easily to a much higher spec i7.
I need a system now ..... gig on Friday ...... I need a second backup machine and cannot afford new from a shop, this guy is a semi retired computer tech with over 600 trades and not a whisper of bad feedback.
http://www.trademe.co.nz/Browse/Listing.aspx?id=622615953
geposted Mon 05 Aug 13 @ 6:53 pm
Hey, he may be legit, but I do not like ATI video cards and the memory it has is weak, to say the least. I wish you all the best, and let us know how things turn out.
geposted Mon 05 Aug 13 @ 11:43 pm
