So i go through itunes and rate the songs in my collection Open VDJ and it doesn't recognize the ratings...so know i have to do it all over again? Am I missing something ? Doing it on VDJ is to much, doesn't seem to let me click on a star level i have to open File infos to change it. Is there a short cut or mapping i can use to make it easier to set ratings?
geposted Mon 05 Aug 13 @ 7:46 am
Currently VirtualDJ does not support reading rating from the tags of files, but this should be possible in a future version of the software.
Also, iTunes does not write the rating back to the tags of the files. It stores it within its own internal database only.
geposted Mon 05 Aug 13 @ 8:10 am
So theres no shortcuts or anything like that?
geposted Mon 05 Aug 13 @ 8:33 am
You could try what's been suggested in another thread...
https://virtualdj.com/forums/177012/General_Discussion/iTunes_Ratings.html
geposted Mon 05 Aug 13 @ 8:51 am
