I had seen in a past post that I cannot find now that someone had said something about changing some of the settings in the Registry Tool for the NS7 if some of the owners could post some of there settings I would appreciate it I have been practicing scratching on it and it just is not sounding right either thank you to all
geposted Tue 06 Aug 13 @ 1:07 am
I know there has to be some other people that have A NS7
geposted Tue 06 Aug 13 @ 1:51 pm
Change DefaultScratchLatency =1103.
In the Performance Tab set :
Latency to Auto
Do not ever check Safe Mode
Scratch = Optimize for Latency
Master Tempo = PureScratch or Advanced Stretching (I use this setting)
Set NS7 ASIO to 5ms or less. I can only get mine to 4ms before I start hearing pops/clicks.
-DJ Kavika
Latency to Auto
-DJ Kavika
geposted Tue 06 Aug 13 @ 3:16 pm
"DefaultScratchLatency" is not used anymore for controllers but only for scratching with the mouse.
It is replaced with "JogScratchLatency" and the new default is optimized for scratch.
You can find some tools to allow you quickly load the older and new defaults for the jog.
In the tool section, also here :
https://virtualdj.com/forums/176910/PC_Version_Technical_Support/Click_and_Fix_Tools__.html
geposted Tue 06 Aug 13 @ 4:04 pm
