Hey people,
Can anyone give me a bit of information.
I have aquired myself a "Hercules" DJ Controller, but the Virtual DJ Home Free software will only allow Ten minutes of use from it. Does this mean I will have to buy a FULL software or is that a way to have my "HOME FREE" version to accept it?
geposted Fri 09 Aug 13 @ 2:44 am
You will have to purchase the PRO Full Version.
geposted Fri 09 Aug 13 @ 3:12 am
You will have to purchase the Pro version unless it came with the LE version, then you can just use it with that.
geposted Fri 09 Aug 13 @ 7:42 am
Ok Thanx Guys.
I can't afford the full version as yet but I have found that the controller works with "MIXXX" software.
Although it don't light up, niether will the jog wheels work. Never mind. I will raise some money.
geposted Fri 09 Aug 13 @ 7:55 am
email the manufacture with the serial number and they might be able to get you a le version... what controller is it. I have had most of them.
geposted Fri 09 Aug 13 @ 10:12 pm
Yes you won't find any software better than VDJ. Save up, hope to see you as a Pro user someday.
geposted Fri 09 Aug 13 @ 11:20 pm
