I have just purchased the Numark Mixtrack Quad and I am busy mapping it to suit my needs.
Is it possible to save my mapping commands so I have them incase I change something by mistake and need to revert back to what I have already done?
Hope that makes sense!
geposted Sat 10 Aug 13 @ 7:41 am
the best way is just to locate the mapping folder and duplicate the mapping, but there is no way to currently automate backing up of files, you should request it in the wishes forum to be considered for the new version.
geposted Sat 10 Aug 13 @ 7:54 am
Thanks I'll do that
geposted Sat 10 Aug 13 @ 8:52 am
How do i configure my keyboard mapping to Play both decks (deck 1 & deck 2) at the same time. What is the proper VDJscript????
geposted Wed 30 Oct 13 @ 10:32 am
choose a keyboard key to use, and map this action for a simple dual deck play "button"
deck 1 play & deck 2 play
More about scripting action :
https://virtualdj.com/wiki/VDJscript.html
geposted Wed 30 Oct 13 @ 10:39 am
thank you for not wasting any time to help. it worked. your greatly appreciated.
geposted Wed 30 Oct 13 @ 10:46 am
hi ive just brought a pionner ddj sz..great controller,but i need to map out the change key function,the only suitable knob is the beat fx knob one on each deck but when i map this out for deck 1 deck 2 will also change key as its playing,just need to tell the mapping only change the beat fx knob that iam trying to change key on.....so
beat fx 1 to deck 1
beat fx 2 to deck 2..
please can anyone tell me how or even better send me the right mapping commands....thankyou..
beat fx 1 to deck 1
geposted Fri 19 Feb 16 @ 3:42 pm
tenho uma controladora Denon Mc 2000 gostaria de saber se existe mapeamento para o virtual 7 no win 8.1
I have a Denon Mc 2000 driver would like to know if there is mapping to the virtual 7 in win 8.1
geposted Fri 19 Feb 16 @ 5:11 pm
It is natively supported in version 7.2 upwards.
geposted Fri 19 Feb 16 @ 5:15 pm
