I can't seem to get my headphones to work in the Numark Mixtrack Quad.
Anyone else having the same problem?
Anyone got any suggestions?
geposted Sat 10 Aug 13 @ 8:55 am
Problem solved.
Needed to split the output.
geposted Sat 10 Aug 13 @ 12:09 pm
The correct sound configuration can be found on the following page:
https://virtualdj.com/wiki/MixDeck%20Quad.html
geposted Mon 12 Aug 13 @ 4:35 am
Hi Wee Phillie,
I just got a new Numark Mixtrack Quad too, and having same problem like what you had (no sounds through headphone!). I'm using Virtual DJ. Attempted to troubleshoot with Traktor 2.5 - same thing, can't get it worked!
The cue comes to speaker - same as master.
Appreciate if you can share how you managed to resolve your problem.
Thanks much.
Miko
Thanks much.
Miko
geposted Sun 29 Dec 13 @ 6:51 pm
What worked for me was going into Inputs>Advanced Config, then setting the Master to outputs 3&4, and Headphones to outputs 5&6.
geposted Tue 25 Feb 14 @ 12:00 pm
Try installing 3rd party ASIO driver like ASIO4ALL and see how the Audio Outputs are routed. Its easier than using Windows WASPI mode since it acts like a aggregate and combines cards as single multi channel audio interface
geposted Tue 27 Jan 15 @ 2:10 am
guess he sovled the issue after almost a year ;-)
geposted Tue 27 Jan 15 @ 2:21 am
It is a Mixtraxk Quad not a MixDeck....
geposted Tue 27 Oct 15 @ 6:21 pm
When correcting someone, it's better to spell check yourself.
Locked by AMAHM
Locked by AMAHM
geposted Wed 28 Oct 15 @ 2:40 am
