Hello, I have a problem with my recording option on VDJ LE... I don't have the configuration button (but I know it's normal in the free version because I owned a hercules with the VDJ LE) and to top it of, when I click on the button "start recording", nothing happens...
Can someone help me please? I got great ideas of mixes but I can't record them T_T
geposted Sat 10 Aug 13 @ 11:30 am
Above the 'start recording' tab there is a 'config' tab. Press that and you have to name the file you are recording. And if memory serves me, you only have the option to record in .wav format.
geposted Sat 10 Aug 13 @ 11:57 am
There is not an Option button in the RECORD page of the LE version, just a START button. Nomrally it should pop-up a window to ask you the location you need to record (path). Recording is available only in wav format, and you cant adjust any recording setting with the LE version.
More recording options, among others, can be found to Pro Full version, which you can have at a significant discount
geposted Sun 11 Aug 13 @ 4:54 am
