I just watched a video on the Ion Discover DJ Pro and to me it looks perfect for what I have been looking for and its right in my price range
The only thing I see I won't use is the iPod dock but other than that I like it
Has anyone used it? If so what are the pros & cons?
Thanks in advance
Thanks in advance
geposted Wed 14 Aug 13 @ 3:54 pm
If you like the Ion controller but don't need the ipod dock you should look at the Numark Mixtrack controllers. It's essentially the same controller only branded for Numark and sans the ipod dock.
Older model: http://www.numark.com/product/mixtrackpro
Latest model: http://www.numark.com/product/mixtrack-pro-ii
Good luck,
Tim
Good luck,
Tim
geposted Wed 14 Aug 13 @ 4:18 pm
This model provides great value you may also want to consider Mixtrack Pro series controllers as these are newer and offer more features.
Where are you located?
Simon (inMusic Brands)
geposted Thu 15 Aug 13 @ 4:25 am
I have a bag full of numark buttons as I keep breaking them. They aren't made to last...
geposted Thu 15 Aug 13 @ 12:53 pm
I've been also checking out the Numark Mixtrack 2 and it looks pretty awesome as well
I've used Numark in the past and have always been pleased with thier products I am currently using the Numark iDJ3 and I've pretty happy with it
I chose that when I upgraded my whole system because it plays cd's however I don't use those much anymore but I will always keep them around for back up
And I am located in Missouri
geposted Thu 15 Aug 13 @ 1:13 pm
@hwm1992
Where at in Missouri? I travel to Joplin from time to time.
geposted Thu 15 Aug 13 @ 2:44 pm
I am an hour and half east of KC
geposted Thu 15 Aug 13 @ 2:45 pm
Oh, that's much farther north than I ever get.
geposted Thu 15 Aug 13 @ 2:57 pm
