Can anyone recommend a really good Echo effect plugin - I have Echo Out & EchoDoppler
Thanks
Paul
Thanks
Paul
geposted Thu 15 Aug 13 @ 6:42 am
I like ramp delay, if you don't change the size it's a brilliant echo and when you move the slider past 50% it will start killing the track send but leave the echo going simulating post fader echo. If you want just an echo the echo_efx500 will kill the echo send over 50%.
If you want a serious echo and are willing to pay for a high quality VST, 'lexicon psp42' is the best, or alternatively ohm_boyz which is a little cheaper but has a different feature set.
geposted Thu 15 Aug 13 @ 9:53 am
i cannot manage echo out to make it work.. nothing happens when i use it.
and echo EFX500 cannot find it on effects list? whats wrong?
geposted Thu 15 Aug 13 @ 11:03 am
they're downloadable effects created by Deun - Deun
geposted Thu 15 Aug 13 @ 11:13 am
Many thanks for the tips I will check them all out !
geposted Thu 15 Aug 13 @ 3:55 pm
Getis both effect are on the plugin pages - I just entered the names in the search box and they came up no problem but I just noticed you are a limited edition user so this could be why you can't get them possibly?
geposted Thu 15 Aug 13 @ 3:59 pm
no no no.. i have download them , i know how to use them. with limited edition u can download effects. i have them all installed but echo out seem to not work for me... nothing happens when i activate it and move the effect slider.
also when i install the echo EFX500 effect it doesnt show up on the effects list of VDJ and i cannot choose it. or maybe its being installed with another name than EFX500?
geposted Thu 15 Aug 13 @ 8:14 pm
you need to either activate the pro trial or upgrade to pro at a discount just enter your serial number on that page to see how much you will be discount
geposted Thu 15 Aug 13 @ 8:59 pm
Getis. .The proof is in the books https://virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html.
It's possible you may have downloaded them during your Pro trial period but it's probably expired now. That's why that effect no longer works. If that's not enough proof I'm sure a Teamer will chime to confirm.
geposted Thu 15 Aug 13 @ 10:35 pm
i havent activate pro trial... and i have wego for 6months now... and i can use the download effects feature... i can also change effects, when i install them they appear on the effects list on the 3 Effect buttons wego have. but the encho out doesnt work. when its installed its says its ok but nothing happens when i use it.
also i use loop out effect and flanged loop out with success also the preinstalled effects. the only effect seem to have trouble, is the echo out and the EFX 500. the echo out doesnt look to work when i activate it and the EFX 500 doesnt show up on the effect list to choose it...
geposted Fri 16 Aug 13 @ 8:53 am
Update your windows libraries and you should be good to go........... For more info on how to do that look in the plugin section at one of the stickies.
Good luck
Good luck
geposted Fri 16 Aug 13 @ 9:30 am
Good luck
Good luck
i cannot manage to find it! i've also tried to google it, nothing... can u show me the way?
geposted Fri 16 Aug 13 @ 9:48 am
geposted Fri 16 Aug 13 @ 9:50 am
To soon Pach, sometimes you gotta make em sweat a little, lol!
geposted Fri 16 Aug 13 @ 9:57 am
hmm... haven't looked at the timestamp.
Next time :)
Next time :)
geposted Fri 16 Aug 13 @ 10:02 am
hi there guys I was wondering if there is a away to convert a windows plugin to mac because I have recently swapped out my windows laptop for a mac and the effects by deun-deun is only available for windows download and I can't find a better echo effect anywhere else please please help.
geposted Tue 14 Jan 14 @ 3:32 am
Sorry, this is not possible unless the author ports the source code for the effect across to Mac and then compiles it as a Mac plugin.
This may also not be possible if the author does not own a Mac (Which is the case for many PC users who have created effects.)
For further information, please contact the effect's author.
geposted Tue 14 Jan 14 @ 6:19 am
