ok guys do any of you use thee internal drives.
if so which make and also what sizes (gb) can i use for new machine w7
geposted Thu 15 Aug 13 @ 4:10 pm
I use a 128gb SSD. It was a reliabilty choice (shock, magnets, etc). Still need a big conventional drive for the storage. I do ALLOT with the OS drive, so 128 should be ok for W7. I am close, but it has never limited me.
I run a Crucial brand one, think it was M4, pretty happy overall but no real performance gains running SATA 2.
geposted Thu 15 Aug 13 @ 5:18 pm
I use a 120GB Samsung SSD for my operating system (W7) and VDJ drive. Can't fault it. boots quickly and never had a problem.
Highly recomended :-D
I still use 3 7200RPM 1TB Seagate drives for storing my music and video but hope to replace them with SSD units ASAP!
Daz
Daz
geposted Thu 15 Aug 13 @ 5:59 pm
thanks lads.but im trying to go for 1tb internal hd.
got new machine so went for this drive http://www.dabs.ie/products/seagate-1tb-laptop-sshd-sata-6gb-s-64mb-9-5mm-hard-drive-8KRV.html?refs=56340000&src=2
got this on say so of guy i bought machine from.im hoping when i get system set up i will have no problems.
still havent used w7 so hoping it will be same setup as xp ie>turn off programms/batt ect i dont need.
geposted Fri 16 Aug 13 @ 3:36 pm
I found out that early Win 7 install discs did not have SSD drivers. Because of that, the install put my MBR on my second conventional drive. All was fine and OS was on the SSD. until I went to upgrade that second drive. Then my PC did not boot because the MBR was gone! [Laughing], there is a fix that a friend did for me, but just a warning.
You may need to get the drivers in order to solve this or a Win 7 SP1 install disc. I heard they added SSD drivers native in the Win 7 SP1 discs.
Just a warning, forgot all that happened over a year ago now.
geposted Fri 16 Aug 13 @ 4:55 pm
cheers mate ill keep your comment to go back to.when i get hd installed.
also the w7 installed on machine is ultimate sp1
geposted Sat 17 Aug 13 @ 6:48 am
