I see that this controller works just awesome with Serato Itch. The main thing that calls my attention is the pads, they are special as they can control effects and stuff. So if you have seen the videos on youtube you know what I'm talking about, or maybe you got one at home.
So my question is, does the VCI-380 work the same on VDJ as on Itch? Do all the features work exactly the same on VDJ?
I know it can be mapped and can work with VDJ but I don't know if the PADS features work the same.
I want this controller but I wanna use it with VDJ of course and not Itch.
Sorry if my english is bad.
geposted Sat 17 Aug 13 @ 4:53 pm
It's hard to tell as there is no downloadable definition file available to check. You could definitely use them but you may have to write a new definition including the pressure sensitivity as it doesn't look like it's been used in the default one.
if you already have the controller, to test change one of the pads to something like this
effect 1 active while_pressed & effect 1 slider 1
if you are modifying the effect parameter with pressure you have your answer, if not you need to make a definition file.
PS it looks like effect 1 & 2 is mapped to the touch strip.
geposted Sat 17 Aug 13 @ 5:30 pm
Thank you, but I don't own one. I'm just asking cuz I want to get one of these.
Anybody else please?
geposted Sun 18 Aug 13 @ 1:45 pm
