Good afternoon, I am creating a skin which I added a panel BPM only option
and I added two buttons one is to divide the bpm by 2, the other button is to multiply the bpm by 2.
the problem is that I find the commands to work.
is the appreciate if they could help me with it.
geposted Sun 18 Aug 13 @ 5:53 pm
You need to use a percentage to set the bpm, remember though that this will change the bpm of the track saved in the browser.
deck # set_bpm 50%
deck # set_bpm 200%
replace # with whatever is most appropriate from [1, 2, 3, 4, left, right, default, "masterdeck"];
"masterdeck" would replace "deck #"
deck # set_bpm 50%
deck # set_bpm 200%
geposted Sun 18 Aug 13 @ 6:37 pm
