Hi, I would like to add a mapper, a key shortcut to turn on and off my echo effect on virtual dj. I've tried but can't find any. Could you guys help me?
geposted Tue 20 Aug 13 @ 7:31 am
effect 'effectName' active
effect 'echo' active
geposted Tue 20 Aug 13 @ 11:07 am
thanks
geposted Tue 20 Aug 13 @ 5:54 pm
hello.. how set echo slider 2 -1/2 bt
geposted Sat 24 Nov 18 @ 10:58 pm
how to set echo slider2 1/2bt. plz help guys as a shortcut
geposted Sat 24 Nov 18 @ 11:01 pm
This topic is quite old and probably the OP is referred to version 7 of VirtualDJ.
In case you are using VirtualDJ 8, then you can use..
or..
... to set the Beats of the Echo FX to 1/2
effect_beats 'Echo' 0.5
or..
effect_slider 'Echo' 2 50%
geposted Sun 25 Nov 18 @ 12:38 pm
tnx a lot it works
geposted Sun 25 Nov 18 @ 6:21 pm
Ola, alguém sabe como bloqueia eco para repetir
geposted Sun 01 Sep 19 @ 3:36 pm
