Hello! I have downloaded some samples and put them in the soundeffect map but when I open samples in the Virtual DJ program I can\'t find the new ones I added. I have uploaded a pic so you can see, are the new effects/samples supposed to appear in the left column, where cut, delay and flanger are?
Would be really great if someone could help me :)
geposted Tue 20 Aug 13 @ 9:03 am
I think I descbribed that kinda bad.... I don't know how to change samplers, I have downloaded som new ones but I don't know how to use them.. And I have downloaded som effects to, (soundeffects like flanger, cut etc) but they wont appear with the other soundeffects in the DJ Virtual program, what am I doing wrong?
geposted Tue 20 Aug 13 @ 9:17 am
samples and plugins are 2 different things.
you mention samples, so you are in the wrong spot.
you need to select the SAMPLER not the EFFECTS like shown in your pic.
after you select SAMPLER, you need to load the downloaded sample or one you created etc... into an available spot (out of 12)
Samples (i.e. recorded sounds) go in the sampler directory. The effects directory/tab is for audio effects - things like echo, delay & reverb that change the sound of the audio played through them.
geposted Tue 20 Aug 13 @ 9:18 am
Thanks for the answers! But how do I put a sampler where it says empty??
geposted Tue 20 Aug 13 @ 10:41 am
I suggest you read the manual. It will teach you how to use the software.
geposted Tue 20 Aug 13 @ 10:47 am
I have, but in the manual the program verison looks different! Take a look :)
geposted Tue 20 Aug 13 @ 10:56 am
Yes, that's just the skin.
The core operation of the software is the same, regardless of skin. This includes the sampler section.
geposted Tue 20 Aug 13 @ 10:58 am
Thanks for the help!! I discovered that I had to activate the pro version to load other samplers etc, so I guess I have to buy it later!
geposted Tue 20 Aug 13 @ 11:12 am
