Hi all
Looking for a bit of advice please. I've been using V-DJ for a long time, and a short while ago I went through my music files and tidied them up - renamed a whole bunch and also sorted the file structure to be more intuitive , which as you can image took a looooong time! What I've found, however, is now when I search for a particular song, It's still finding the old file names (which inevitably produce an "error" message, since the file is no longer in that location) as well as finding the real file within my new file structure. Is there any way to "unmap" or make the program "forget" the previous location so it stops creating duplicate results upon searching?
Many thanks in advance!
Tigernutz
Tigernutz
geposted Thu 29 Aug 13 @ 2:57 pm
Config> Browser then select check, clean
Keith
Keith
geposted Thu 29 Aug 13 @ 3:10 pm
...and last but not least FIX!!!
(Check - Clean - Fix)
geposted Fri 30 Aug 13 @ 2:20 am
I don't seem to have a "config" option O.o could it be a skin hiding it? Is there a shortcut to get to it?
geposted Thu 12 Sep 13 @ 5:31 pm
