My sound issue has been addressed in my earlier post title "sound"
After hours and days of frustration trying to get things to work like its supposed to
I get to my gig tonight excited because I finally got everything set up proper
Well I was an hour behind getting started because I had no sound
And before anyone asks yes I left all the settings the same once it was set right
I hooked up everything just like I was told to my previous post
So in order for me to get sound I am now using both the sound card in my laptop and the controller
And I had to go back to using output to output just to get sound
Maybe software problem? Maybe hardware problem? Operator error?
geposted Fri 30 Aug 13 @ 11:57 pm
I was in your 'similar' situation when I first got on with VDJ. Turned out it was operator error(I will admit it lol). User's here are willing to help you.
May I suggest at this point that maybe instead of creating another thread on troobleshooting your issue, could you post a video DETAILING your equipment and how you are setting things up?
This way, the more experienced sound guy's can have a better understanding of your system setup. Just a thought..
geposted Sat 31 Aug 13 @ 1:14 am
That's a great idea thank you I have another gig tomorrow if time allows I'll do a video
Thanks for the help
Thanks for the help
geposted Sat 31 Aug 13 @ 3:16 am
As above, please continue any discussion in your previous thread as all the information is there.
TOPIC LOCKED
Keith
TOPIC LOCKED
Keith
geposted Sat 31 Aug 13 @ 3:57 am
