Okay so I have an m101 2 channel mixer, and 2 gemini cdj 203s. I put in a cd and the cdj's won't read it, I have one plugged into ch1 line, and the other ch2 line. Please help.
geposted Sat 31 Aug 13 @ 9:06 am
Sounds like you need Gemini support, not Atomix/VDJ...
You say it's "a CD" - what type of CD? Is it an audio CD you've bought, or one you burned, or a data CD with MP3s on?
What happens when it "won't read"? Is there a message or error code of any kind? Does it eject back out? Does it spin but not play?
It helps to be more specific when you post, so people can answer you without having to ask more questions.
geposted Sat 31 Aug 13 @ 9:33 am
Its a cd with mp3s on it. it just keeps making weird sounds. it doesnt eject or say anything. just track 1-100 scroll menu.I think it spins up then stops over and over again
geposted Sat 31 Aug 13 @ 11:02 am
You burned it yourself then, I guess.
Two possibilities here:
One is that the Geminis simply can't play MP3 discs. They're cheap units, so they may well only play actual audio CDs. Check the manual.
Two is that the brand of blank CD you used is not compatible with the laser in the player, or that the player doesn't play burnable CDs. Again, check the manual.
geposted Sat 31 Aug 13 @ 2:42 pm
it says it will read cd-r (the disc im using) this is really frustrating. Everything works except for the m101.
Let me go over this in as much detail as possible.
The cdj's work fine, probably going to get new 1's because they won't read the discs, anyways thats not the problem.
Whenever i load the 2 songs onto the m101, I can use the bass and treble on both, and the volume knob.
But, I can't use the cross fader or the volume lever
I might as well just sell the cdj 203's, they are a piece of crap.
Anyways do you know why the m101 isn't working?
I have rca cable hooked up ch1 line and ch2 line
geposted Sat 31 Aug 13 @ 3:14 pm
You said the Geminis weren't working.
ClubDJ 77 wrote :
The cdj's work fine
You said they didn't.
You said it was.
What, the master volume knob.....or the channel gains?
Please explain "can't use". What are you expecting and not getting? You do realise that both channel faders need to be up for the crossfader to switch between one channel and the other? And what's a volume lever?
geposted Sat 31 Aug 13 @ 3:41 pm
