My USB hard drive stopped working during my set. It showed up, but my database file got erased. After a reset, it was fine. Also another time, my virtual folders/database came back randomly after a few minutes.
I am wondering if anyone else has had this issue? Maybe it was a power thing because I was running system and lights on full on the same circuit?
Thanks
Thanks
geposted Tue 03 Sep 13 @ 12:22 pm
You should change all your power saving settings to off. Your USB ports have settings to always stay powered, make sure they are set to that. Same thing with the harddrive, make sure to take it off hibernating mode.
Here you will find more tips for better performance http://www.virtualdj.com/wiki/Performance%20Issues.html
geposted Tue 03 Sep 13 @ 12:35 pm
