I'm probably not looking and seeing but wondered how to adjust the volume of the samples. If I use the presents they are to heavy and if I record my own then not enough. I'm just getting to grips with VDJ done a few gigs have some more booked so must be doing something right. But this sample volume thing I never cracked.
DJ Crazy Steve
DJ Crazy Steve
geposted Wed 04 Sep 13 @ 12:55 pm
Normally located at center of skin. You will see the tabs Browser, Effects, Samples, Rec. Click on Samples and you will see all the Sample volumes and options.
geposted Wed 04 Sep 13 @ 1:34 pm
It's a balance only you can figure out. You have to find the sweet spot for you. There is volume control in the sample bank, so once you decide on a acceptable volume, you can adjust to your liking. In the pro version, you are able to send the sample to a different channel, and have more control over the volume.
geposted Wed 04 Sep 13 @ 1:35 pm
Thank you
I found the way with your help thanks again and yes I'm saving hard for the pro version.
geposted Wed 04 Sep 13 @ 4:02 pm
