Topic: vdj pro
hi im new to the forum but im looking for a bit of info
ive got vdj pro, numark n4 and just got a set of decks. i want to use timecode would the RANE SERATO SCRATCH timecodes work with vdj pro. any help and information would be great
cheers
geposted Fri 06 Sep 13 @ 9:44 am
If you've got VDJ Pro then the first thing you should do is register the serial number to your account here, so that you can download the latest updates - which will include VDJ 8 when that's released.
All the compatible timecodes are listed on a drop down menu in the timecode config of VDJ.
