Having troubles with VDJ. Just had a laptop built to work great with VDJ. It exceeds the recommendations and yet while playing videos I can't see my pop up menus for file info, ect. Also if I go into Configuration it does it too. The pop up menu goes behind the VDJ program. I can only fix this by pressing CTRL, ALT, DEL. When I do that though my video screen on a monitor or TV goes to white and I have to De-activate it. Anyone else have this problem?? Here's what my computer has for specs, 4th Gen. Intel Core i7-4700MQ Processor, NVIDIA GeForce GTX 770M GPU with 3GB GDDR5 Memory, 750GB SATA2 Hard Drive.
geposted Fri 06 Sep 13 @ 1:10 pm
Never heard about that.
But try alt+tab instead of strg-alt-del
EDit: what is your output device for video?
If it is just the video window, then the window will always be on-top.
Change to a smaller size or use a 2. output device for fullscreen video output.
geposted Fri 06 Sep 13 @ 1:14 pm
If I just use the window it works fine. If I extend my background and use NVIDIA or use Intel(R) HD Graphics on either a Monitor or a HD TV I run into these problems.
geposted Tue 10 Sep 13 @ 3:59 pm
