Hello, I Have two Denon DN SC2000 controllers and want to get them to work with vdj
My problem is that I dont get any midi signals into vdj. In other software like ableton live I get midi signal when I push button or rotate jog wheel. But in VDJ I get nothgin :(
I can see the device in Setting --> Mappers, it says Denon DN-SC2000 and some keys are mapped but I get no reaction. I try 'Key-Learn' but no reaction to any keystrokes.
On top on that, I cannot find any midi mappings for VDJ from stupid Denon site... :/
Do you know how to fix this problem?? Please help
geposted Sat 07 Sep 13 @ 4:37 am
[SOLVED]
YAAAY! I found the solution!!!
The secret is to press Shift + Browse/Previous/Next/Duplicate on controller to choose the midi channel!
The mapping works automatically. Thank you!
geposted Sat 07 Sep 13 @ 4:59 am
I suppose Midi Channel 1 needed to be selected on both. That is always the case.
geposted Mon 09 Sep 13 @ 12:26 am
