Not sure what I did but from the time I added some new effects and samples tonight and removing ones I don't want
my music won't fully load!
Any suggestions?
Would uninstalling VDJ and reinstalling VDJ solve the problem?
Any suggestions?
geposted Tue 10 Sep 13 @ 8:49 pm
Check the CONFIG, PERFORMANCE, MEMORY setting and make sure that it is set to a time which is longer than the run time of the songs you are trying to load.
Daz
Daz
geposted Tue 10 Sep 13 @ 9:51 pm
Ok cool I'll try that....I just find it odd that I never had any problems until I went to deleting stuff Lol
I'll try that first
Thanks
I'll try that first
Thanks
geposted Tue 10 Sep 13 @ 10:32 pm
I've had the same issue and sometimes it was the length setting, but at other times it was because my ram was filling up. I used the reg tool from the plugin section to adjust how much ram the video could use up. I've set it really low without any ill effects. If the length setting doesn't work. Open task manager while your playing video's and watch your mem to make sure that it doesn't get used up.
geposted Wed 11 Sep 13 @ 3:02 am
Hey Daz thanks for the info
I went in and changed the length and it worked
geposted Wed 11 Sep 13 @ 10:13 am
