ANNOUNCING, THE PIONEER DDJ-SR FOR SERATO DJ
Designed with the highly popular DDJ-SX in mind, the Pioneer DDJ-SR offers the same high performance and advanced control in a smaller package, as well as some new and unique features of its own. The DDJ-SR is a two channel controller with four deck control, has dedicated Serato DJ performance controls, velocity sensitive pads and an all new Pad Plus mode. One-up your performance pads and unlock brand new features (Hot Cue Roll, Transform, Combo FX and Sample Roll).
Read on to find out what’s coming!
Hardware Features
USB powered. No need to find an extra power outlet.
Hardware Aux input (RCA). Ideal for connecting a secondary device to play mixes or playlists when there’s no-one DJing.
Single Mic Input (1/4” jack) for you to get hype on.
Master (1/4” jack) and Booth outputs (RCA).
Both 1/4” and 1/8” mini jack headphone outs.
USB 2.0 port for straightforward, plug-and-play connection with Serato DJ.
Velocity sensitive pads for expressive sample player control.
High resolution, touch sensitive jog wheels.
Combo HP/LP filter for each channel.
New Features available with the Pioneer DDJ-SR & Serato DJ
Velocity Mode. Previously available on the DDJ-SX, this feature allows expressive use of the performance pads for SP-6 Sample Player control. The harder/softer you hit the pads, the louder/quieter the sound will play. This is particularly useful with drum samples.
Pad Plus is a unique feature to this controller and opens up four, brand new modes to your performance pads.
Hot Cue Roll - Hit cues and have them re-trigger in a range of beat divisions. Similar to a note repeat function.
Transform - Hit and hold the pads to turn on a transform effect in a range of beat divisions.
Combo FX - Gives you momentary control of Multi-FX with your performance pads.
Sample Roll - Trigger samples in the SP-6 and have them re-trigger in a range of beat divisions. Similar to a note repeat function.
Four decks. The DDJ-SR has dual-layer mixing controls giving you the ability to mix up to four decks on this two channel controller.
Head to our Serato DJ page for more information on the existing Serato DJ features available to all controllers.
Available this October and supported in Serato DJ 1.5, the Pioneer DDJ-SR is the latest in their professional line-up of all-in-one DJ controllers. Look out for more info from Pioneer about when hardware is shipping and prices.
Hardware Features
geposted Thu 12 Sep 13 @ 2:19 am
Geschätzter Strassenpreis 599 Euro.
geposted Thu 12 Sep 13 @ 3:23 am
richtig eng zusammen geklatscht alles. ok anzeige für loops und der neue padmode ist interessant. dafür ist der pitchfader noch kürzer geworden als beim xdj r1. beatmatchen sehe ich da als problem
geposted Thu 12 Sep 13 @ 6:55 am
Ich möchte endlich wieder einen Controller mit den guten alten gummierten Denon Play Tastern...
- Kein EQ für Mic
- nur Klinke und chinch Ausgang
- nur ein AUX in und die Lautstärke macht man wenn man hinter den controller packt... also im Case wieder schlecht zu erreichen wenn der Lappi auf dem Schlitten steht.
Wer ist eigentlch dieser technologe der das Design für die Controller macht...der hat doch keine Ahnung!
Nur weil da jetzt 8 Taster drauf sind für Effekte ist das noch lange kein guter Controller...
- Kein EQ für Mic
geposted Fri 13 Sep 13 @ 4:11 am
Schön wäre mal wenn es mal einen Controller geben würde, "von DJ´s für DJ´s", die um die praktischen Features im Liveeinsatz Bescheid wissen....
geposted Fri 13 Sep 13 @ 4:32 am
Ja selbes wurde im Ami Forum auch gesagt.
Wer entwickelte diese Teil? Keine Ahnung der Typ, denn:
Der SX mag ja für den Club super sein, sofern man den Platz hat.
Für mobile DJs aber eher ungeeignet aufgrund der Größe.
Dieser kleinere Controller soll jetzt wohl die mobilen DJs ansprechen.
Diese aber arbeiten, im Gegensatz zu reinen Club DJs, öfter und regelmäßig mit dem Mic.
Da dieses aber wohl nicht sehr gut umgesetzt ist (u.a. fehlende EQs) kommt für die meisten
dieser Controller für den mobilen Einsatz wohl nicht in Frage.
Fazit: Einfach nur teuers Spielzeug mit wenig praktischen Nutzen.
Ist ja in vielen Situationen so. Was die Designer gut finden, muss noch lange nicht praktikabel geschweige denn partisch sein.
Fragt mal bei BMW an was es für einen Streit zwischen den Designern und Ingenieuren wegen des GT gab. Das Projekt wäre fast eingestellt worden.
Und was die BWL'er bei uns für gut empfinden, halten wir in der IT noch lange nicht für gut.
geposted Fri 13 Sep 13 @ 8:01 am
