I copied my song database onto a thumb drive (which have the comments the same as the genre) and then copied to another computer. When I go and look at the genre in Virtualdj on the new computer, it appears to have changed and is no longer the same as the comments.
Any ideas on why this happen would be appreciated.
Thanks
Thanks
geposted Sat 14 Sep 13 @ 11:52 am
Thanks
Thanks
Copy the music from your EX-HD then open it with vdj and scan the thumb drive,Copy the music to the 2nd computer in a new folder but dont move until you with the thumb plug in,then open VDJ scan your music for NEW music and the INfo from the thumb will be move to the NEW folder.DONT move the song out of order until VDJ read it 1st.
geposted Sat 14 Sep 13 @ 4:50 pm
