ok now i been having issues with this virtualdj problem for a while i pay for it online i need some one out there help me r im doing some thing wrong here. i sent yall massage sayn im havn problems with this freakn virtual dj program NO RESPONSE BACK come on if some one payed a program online and haven problems yall should have a 24 hours phone line service r something this is crap. now the problem im havn with virtual dj pro is whn i mix videos on there it starts to stutter the videos laggs i have put new ram and a good upgrade video card call RADEON HD 6450. Let me know if im doing something wrong here. thank you.
General
Packaged Quantity 1.0
Type Personal computer
Product Form Factor Tower
Built-in Devices LED panel
Processor / Chipset
Type AMD Phenom X4 9100e / 1.8 GHz
Number of Cores Quad-Core
64-bit Computing Yes
CPU Qty 1.0
Max CPU Qty 1.0
CPU Socket Socket AM2
Chipset Type AMD 780G
Front Side Bus 3600.0 MHz
Cache Memory
Installed Size L2 cache - 2.0 MB
RAM
Installed Size 4.0 GB / 8.0 GB (max)
Technology DDR2 SDRAM
Memory Speed 800.0 MHz
Memory Specification Compliance PC2-6400
Form Factor DIMM 240-pin
Features Dual channel memory architecture
Configuration Features 2 x 2 GB
Upgrade Rule Max 2 x 2 GB module
Hard Drive
Type HDD
Capacity 1.0 x 640.0 GB
Interface Type Serial ATA-300 Serial ATA
Spindle Speed 7200.0 rpm
Storage Controller
Type Serial ATA - Integrated
Controller Interface Type Serial ATA-300
Hard Drive (3rd)
Type None
Optical Storage
Type DVD±RW / DVD-RAM
Read Speed 48x (CD) / 18x (DVD)
Write Speed 48x (CD) / 16x (DVD) / 12x (DVD-RAM) / 8x (DVD Double layer)
Disc Labeling Technology Labelflash Technology
Optical Storage (2nd)
Type None
Card Reader
Type 15 in 1 card reader
Storage Removable
Type None
Monitor
Monitor Type none.
Graphics Controller
Type Integrated
Graphics Processor / Vendor ATI Radeon HD 3200
Video Memory 256.0 MB (max)
Max Allocated RAM Size 256.0 MB
Video Interfaces VGA,
HDMI
Input Device
Type Keyboard,
Mouse
Audio Output
Type Integrated
Audio Adapter Integrated Audio
Sound Output Mode 7.1 channel surround
Compliant Standards High Definition Audio
Speaker(s) 2.0 x Right / left channel
Audio Input
Type None
Telecom
Modem Fax / modem
Max Transfer Rate 56.0 Kbps
Protocols & Specifications ITU V.92
Mouse
Technology Optical
Interface USB
Features Scroll
Networking
Type Integrated
Data Link Protocol Ethernet,
Gigabit Ethernet,
Fast Ethernet
Printer
Type None
Miscellaneous
Cables Included Power cable ( 1.0 pcs.)
Expansion / Connectivity
Slots 1.0 (total) / 0.0 (free) x Memory PCIe x16,
4.0 (total) / 0.0 (free) x PCI Express x16 PCIe x1,
1.0 (total) / 0.0 (free) x PCI Express x1 CPU,
1.0 (total) / 0.0 (free) x Memory card reader DIMM 240-pin,
2.0 (free) x PCI PCI
Interfaces 8.0 x PS/2 mouse Audio - USB 2.0 ( 2 in front ),
1.0 x PS/2 keyboard RJ-11,
2.0 x LAN (Gigabit Ethernet) RJ-45,
1.0 x Modem,
1.0 x HDMI,
1.0 x VGA,
6.0 x FireWire,
1.0 x USB 2.0,
1.0 x
Power
Device Type Power supply
Power Provided 300.0 Watt
Operating System / Software
OS Provided Microsoft Windows Vista,
Microsoft Windows Vista Home Premium 64-bit Edition
Software Norton 360 (60 days trial),
Microsoft Works 9.0,
Microsoft Money Essentials,
CyberLink Power2Go,
Microsoft Office 2007 Home and Student Edition (60 days trial)
Dimensions & Weight
Width 7.1 in
Depth 17.3 in
Height 16.3 in
Weight 24.3 lbs
General
Processor / Chipset
CPU Qty 1.0
Max CPU Qty 1.0
Cache Memory
RAM
Hard Drive
Type HDD
Storage Controller
Hard Drive (3rd)
Type None
Optical Storage
Type None
Card Reader
Storage Removable
Type None
Monitor
Monitor Type none.
Graphics Controller
Type Integrated
HDMI
Input Device
Type Keyboard,
Mouse
Audio Output
Type Integrated
Audio Input
Type None
Telecom
Modem Fax / modem
Mouse
Technology Optical
Interface USB
Features Scroll
Networking
Type Integrated
Gigabit Ethernet,
Fast Ethernet
Printer
Type None
Miscellaneous
1.0 x Modem,
1.0 x HDMI,
1.0 x VGA,
6.0 x FireWire,
1.0 x USB 2.0,
1.0 x
Power
CyberLink Power2Go,
Dimensions & Weight
Width 7.1 in
Depth 17.3 in
Height 16.3 in
Weight 24.3 lbs
geposted Mon 16 Sep 13 @ 3:11 pm
Do not spam the forums by posting the same message over and over again. This will not get you a faster response and your account will be locked if you continue to break the forum rules. Please wait patiently for a response to your first post. Also, for the fastest response, make sure that you use the correct forum for your question when posting, so that it is seen by the most users who may be able to help you.
Please read the following FAQ pages:
https://virtualdj.com/wiki/My%20video%20output%20runs%20slowly%20or%20is%20very%20choppy.html
https://virtualdj.com/wiki/Video%20Memory%20Issue.html
Also, make sure that your computer has also been optimised for DJ performance:
https://virtualdj.com/wiki/Performance%20Issues.html
You can also open a support ticket for more direct assistance if you have not done so already by going to: https://virtualdj.com/contact/ - If you have not received a response yet, then please see https://virtualdj.com/wiki/How%20long%20does%20it%20take%20to%20get%20an%20answer.html
geposted Tue 17 Sep 13 @ 5:32 am
First of all Relax....... the support from Atomix is very helpful, also you will find that most of us on here will try and help you as well, ok with that being said....
You're running windows vista....... that in itself can be a problem Vista has A LOT of tasks running in the background that you probably aren't aware of, you need to check and see what and how many programs are running in the background. I have seen over 100 processes running at once on Vista add VDJ with video and you will have issues!
You need to optimize your computer ( stop the programs you dont need running while you are djing and turn off Vistas Aero mode )
You upgraded your video card, according to the pc specs you posted you have a 300 watt power supply, if youre taxing your pc that power supply is on the low side and will cause problems
Upgrading from Vista to Windows 7 64-bit would help, I am personally not a big fan of amd processors, but that's just my opinion
geposted Tue 17 Sep 13 @ 8:45 am
Usually i would reccomend a nVidia GTx5xx or higher...
did you made the video settings with the registry tool
and can you please post a screenshot of your videosettings in VDJ...?
geposted Tue 17 Sep 13 @ 10:48 am
Thanks guys. okayyy,quick question, so u saying my video card i got right now its good for video mixing Readon Hd 6450 Graphic video card and my videos its not gonna lagg r stutter and freeze up my videos whn i press record on the virtual dj. all i have to do is set it up to mp4 h264 not xvid and get videos thats a MP4?
geposted Tue 17 Sep 13 @ 11:15 am
I bought the same graphics card as an upgrade from my AMD HD5xxx series card only to have the same issue as you're having, so i ended up sticking with my previous card and using the HD6xxx card in my media centre.
If anyone can come up with a solution to this id like to see as the newer of the 2 cards has a HDMI port instead of a 'Display Port'
geposted Tue 17 Sep 13 @ 11:17 am
how can i do a screen shot of my video settings sir?
geposted Tue 17 Sep 13 @ 11:18 am
hey guys how bout this one here this a good video card for video mixing --------- EVGA NVIDIA GeForce GT 610 1024MB DDR3 PCIe 2.0 x16 Video Card?
geposted Tue 17 Sep 13 @ 11:23 am
How to do a screenshot in Vista.
http://graphicssoft.about.com/od/microsoft/ht/snippingtool.htm
geposted Tue 17 Sep 13 @ 11:42 am
Bro I have win7 64 bit
geposted Tue 17 Sep 13 @ 12:34 pm
CyberLink Power2Go,
This is from your list of specs. Says Vista. Either way should be the same, here's another way.
http://www.wikihow.com/Take-a-Screenshot-in-Microsoft-Windows
CyberLink Power2Go,
geposted Tue 17 Sep 13 @ 12:45 pm
Ok cool later on tonight I check getin ready for wrk. Thank you bro.
geposted Tue 17 Sep 13 @ 12:56 pm
when i put a song into the DJ from my pc that i had b4 i downloaded the home edition it says error and i cant play them (.mp3) is it bcuz its .mp3? if so, what does it have to be?
geposted Tue 17 Sep 13 @ 3:52 pm
Yeah u rite roy my bad homie
geposted Tue 17 Sep 13 @ 3:58 pm
Lass,
Please start your own thread for your issue, this has nothing to do with Spark's video issue.
In fact I'll make it easy for you. Click here to start your own thread.
Cheers,
Roy
Cheers,
Roy
geposted Tue 17 Sep 13 @ 3:59 pm
Might be OK ...i would prefer 2GB Ram like the the GTX 660 for example...
geposted Wed 18 Sep 13 @ 8:37 am
Are you only having these video problems, when you try to record?
geposted Wed 18 Sep 13 @ 11:52 am
