I touched my mimimise button.Now virtual dj won't load i re-installed the programme its still the same.The icon is there at bottom of screen will not load..using windows 7
geposted Thu 19 Sep 13 @ 9:16 am
Won't load? If the icon is in the taskbar, then VDJ is loaded (running). You should be able to just click on the taskbar icon and VDJ will be there. Are you new to Windows?
Another thing you can do is right click on the VDJ shortcut on your desktop, select properties, select the shortcut tab... In the drop down box to the right of where it says Run: select Maximised or Normal Window.
geposted Thu 19 Sep 13 @ 10:27 am
