Topic: Add Multiple Track BPM Edit Feature.
A nice feature to add to Virtual DJ would be a multiple track BPM edit feature. Say I scan a folder for BPM's, and several of the files have a doubled BPM. The way it is now, I have to click each individual track, click edit, and 1/2 the BPM for each one. It would be nice if I could click several files at once and edit them all by 1/2 BPM. That would save a ton of time.
geposted Fri 20 Sep 13 @ 8:25 am
Create a filter folder or a virtual folder which contains all your tracks you wish to change.
Then read this:
synthet1c wrote :
you could make macro command to do it...
first you need a filter folder that will find any track above 120 bpm, just right click a filter and select new and paste this into the box
bpm>=120
now when you select the filter you will have all the tracks you need to modify.
For the macro you should map it to your keyboard, I will give you 3, the first will change the tempo for 50 tracks, the second for 10 tracks and the third for one track, this way you can do exactly what you have in the filter folder in the least amount of clicks possible.
50 Tracks
deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1 & deck 1 load & deck 1 set_bpm 50% & browser_scroll +1
10 Tracks
1 Track
Or that
streetkingvi wrote :
Better way to do it..... this way it will stay permanently fixed in your folder.
1. go to the config, then go to mapping, select keyboard from the drop down menu.
2. click the key learn button and select the ~ button on your laptop or desktop keyboard
3. in the code bar underneath the word action, paste this code:
deck 1 load & deck 1 set_bpm 50% & deck 1 unload & browser_scroll +1
4. click the ok button to save the change.
5. go to you folder that contains all you hip hop records that read in double time ex: 65 bpm reading as 130bpm
6. go to the track where all your double time records start and highlight the first record.
7. after that just start hitting the ~ button and watch your files transform.
:note you cannot do this when a track is playing in A.
note 2: if you use a controller like a hercules steel that has extra buttons you can also set one or 2 of the buttons to do this
conclusion: if you do this you can fix all your double timed bpm records within 10-20 minutes! then they will all ready as they are supposed to when loaded!
#urwelcome #afterdarkempire @selectabigbeast #happyjuggling
