Hi everyone.
I need a XML database file updating from V5 to V7. Is this possible?
At the moment, my database won't read in V7 as it is still a V5 file.
Cheers.
Cheers.
geposted Fri 20 Sep 13 @ 4:52 pm
you need to update from 5 to 6, then 6 to 7 to get your old database converted. Contact support and they can put older versions in your downloads page
geposted Sat 21 Sep 13 @ 1:09 am
@madjacsdisco,
you will fin in your download center now the Cue 6.2.1 version.
Just try it as synthet1c has adviced.
Best would be to backup the database before.
geposted Mon 23 Sep 13 @ 7:12 am
