Few days back I was working on a set and had a small problem. there are few tracks which i don't want to play complete, because I think it ruins the dance vibe. So what i did i set up cue points in the track. Now the problem I face is when i jump to a certain cue point the track stops for a second or you can say a break appears. how can i solve this problem i want a smooth transition.
geposted Sun 22 Sep 13 @ 3:46 am
You might be having latency issues. Give us more detail on what hardware you are using and what your computer specs are. This way other user's will have an understanding of what equipment you are using and to better assist you with your issues.
geposted Sun 22 Sep 13 @ 4:03 am
He's posted this same question in the "mix lessons" forum.......except there he mentions that he's using Traktor!
So not only is he cross posting but he's on the wrong forum. :-)
geposted Sun 22 Sep 13 @ 4:46 am
Please do not double post. Which version of VDJ are you using?
geposted Sun 22 Sep 13 @ 4:12 pm
