Hey all,
So I am trying to search through my tracks by the key and it isn't coming up with any results when I do so. I have "Key" selected in the little magnifying glass menu and nothing else and when I type in something like "fm" nothing comes up even though I know I have tracks in Fm. The BPM search function also doesnt work but the title search seems to work fine. Anyone know why this isnt working? It's buggin the shit outta me.
geposted Mon 23 Sep 13 @ 5:50 pm
Which Version of VDJ do you use exactly...? See at Config/ Info...
Search in drives + search in folders also active...?
geposted Tue 24 Sep 13 @ 1:25 am
The version I have is 7.4 and yes it is set to search in drives and folders.
geposted Wed 25 Sep 13 @ 6:17 pm
You can only use the numeric values for search, so it would be wiser to show the Keynumeric field in the browser.
Eg. type in Search .. 11A or 06A
For BPM, you need to use a range. E.g. 129-130
geposted Wed 25 Sep 13 @ 8:14 pm
Ooooohhhhh ok awesome that worked! Thanks a bunch! Is this a new change? I used to just be able to type in Am or Bm or whatever.
geposted Thu 26 Sep 13 @ 7:54 pm
I did same, putting in numbers but still nothing showing that i know i have stuff in there 11D#m fo9r instance...nothing?
geposted Tue 17 Dec 13 @ 10:33 am
