hi what is the best config for xdj-r1..... between 64 and 1920 ? thank you for answering
geposted Wed 25 Sep 13 @ 5:06 pm
The best config is the one that works on your setup.
Get the ASIO buffer as low as you can without causing the sound to glitch. Maybe for safety, consider knocking it back up a notch.
geposted Wed 25 Sep 13 @ 6:38 pm
ok thank you ^^^^
geposted Thu 26 Sep 13 @ 5:23 pm
