How do you send messages to other members
geposted Wed 25 Sep 13 @ 9:04 pm
Simply go to a post, click on the underlined name of the user you wish to PM (in the left hand corner), right above where their status as a limited, pro or premium user is noted.....Once you click on their name, you are taken to their profile page on which they may or may not have entered any info (everyone has one). Then right under their profile are 2 icons, one blue (to add as a friend) and the other to PM.....Hover over the icon adjacent to the blue "add as friend" icon and you will see it says "PM ______". Then just send your message to them......Hoped that was clear enough, if not maybe someone else can post you a screen shot.... ; )
geposted Wed 25 Sep 13 @ 9:12 pm
okay its a author of a plug-in but i cant click his name----------> djrjvdj...and cant find a post in search
geposted Wed 25 Sep 13 @ 9:19 pm
https://virtualdj.com/homepage/djrjvdj/
you need to search the name on the "users network" page under the "community" dropdown above
geposted Wed 25 Sep 13 @ 11:07 pm
