Hola...tengo el DDJ wego (me compre de segunda mano), y lo estoy tratando de usar con el VDJ 7 pro, he buscado el mapeo para el VDJ y no encuentro por ningun lado...entences lo hice con el simple mapeo que encuantra el VDJ....casi todo ya lo he mapeado...pero lo mas importante que yo queria hacer es scratching o un slipmode...pero no puedo!!!!!!...estoy desesperado, no encuantra la manera de como mapear eso....por favor si alguien me puediera ayudar...o alguien que me diga que definitivamente ya no tiene solucion...Gracias
geposted Thu 26 Sep 13 @ 8:15 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of https://virtualdj.com/forums to post in your own language.
geposted Thu 26 Sep 13 @ 8:32 am
Hi ... I have the DDJ wego (I bought used), and I'm trying to use with VDJ 7 pro, I searched the mapping for VDJ and not find it anywhere ... I did entences simply that well.The the VDJ mapping .... almost everything I've mapped ... but more importantly I wanted to do is scratching or slipmode ... but I can not!! ... I'm desperate, not as well.The how to map it .... please someone help me ... or someone puediera tell me that definitely has no solution ... Thanks
geposted Thu 26 Sep 13 @ 8:43 am
The WeGO is already supported in VDJ Pro.
If you register your Pro serial number, then you can download the latest version of VDJ Pro and the WeGO will work.
geposted Thu 26 Sep 13 @ 8:54 am
and LEDs will work?
geposted Thu 26 Sep 13 @ 10:10 am
Yes they do.
As above, simply register your Pro serial number to your account https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it at your gigs.)
You can test it before purchasing for 10 minutes at a time in VirtualDJ Home FREE: https://virtualdj.com/download/free.html
geposted Thu 26 Sep 13 @ 10:37 am
