So I built multiple play lists, all appear as subfolders to the Playlists main folder. I right click on a play list under the main folder and select load into play list so I can automix the list. The play list goes to the play list section, but also appears in the browser section.?? Then when I choose to open the entire library in the browser section, the play list in the play list section disappears. What's going on? I would think if I send a play list to the play list section, it should stay there oblivious to the rest of the world.??
geposted Thu 26 Sep 13 @ 7:01 pm
The middle section of the browser always shows you the contents of the folder, playlist, etc. that you have selected on the left-hand folder list.
The right-hand playlist section holds the playlist that you currently have loaded. By default, if you click on a playlist in the folders list, it will be loaded automatically (This can be disabled in CONFIG -> Options if you wish.)
geposted Thu 26 Sep 13 @ 7:43 pm
Disabled autoload playlists and now it works to my preference, Thanks!!
geposted Sun 29 Sep 13 @ 4:05 am
