hows it going fellas,?
I was wondering if there was any midi mappers for the kontrol z2 mixer either available already or somebody could point me in the way of making my own custom mapper for it...thank you in advance..
geposted Tue 01 Oct 13 @ 12:47 am
thanks for the help but the link doesnt work ..i have a mac lool
geposted Tue 01 Oct 13 @ 11:10 am
there are some applications on Mac side, but i doubt if anyone can help you from here, since most of use map devices on Windows and Miditrace/Hidtrace/Midi-OX
http://www.snoize.com/SysExLibrarian/
http://notahat.com/midi_patchbay
http://midipipe.en.softonic.com/mac
Instructions https://virtualdj.com/wiki/Controller_Definition.html
geposted Tue 01 Oct 13 @ 1:05 pm
Does the Mac version of VDJ not have the same MIDI learn capability as the PC version?
You should be able to just plug the Z2 in (once it's in MIDI mode), go to the mapping tab under the VDJ config and start mapping the Z2 controls to VDJ functions.
geposted Tue 01 Oct 13 @ 1:24 pm
Doesn't always work like that Groovin.
geposted Tue 01 Oct 13 @ 2:14 pm
You need to make a definition if you want to use LED's groovin. I can't imagine spending all that cash on a Z2 without wanting to leverage the RGB LED's.
Congrats on the upgrade Huey!!
geposted Tue 01 Oct 13 @ 6:44 pm
