me and synthetic have been trying to right this script for days....ive been able to get this to work as a basic work around while we he finishing coding my my ideas but i would like to see if someone can help with this small workaround here the script
Vestax VCI-400
shift button
set '$shift' 1 & holding ? set '$shift' 0 : set '$shift' 0 & toggle '$sampler' & var 'sampler' ? page "sampler" : page "browser"<---this is the problem. I want to hold shift and delete the hot_cues by holding shift and hit the hot cues.
Pads 1-8 and mode button 1-4<<these are right
var '$sampler' ? sampler 1 play_stutter & sampler 1 select : hot_cue 1
var '$sampler' ? sampler 2 play_stop & sampler 2 select : hot_cue 2
var '$sampler' ? sampler 3 play_stop & sampler 3 select : hot_cue 3
var '$sampler' ? sampler 4 play_stop & sampler 4 select : hot_cue 4
var '$sampler' ? sampler 5 play_stop & sampler 5 select : hot_cue 5
var '$sampler' ? sampler 6 play_stop & sampler 6 select : hot_cue 6
var '$sampler' ? sampler 7 play_stop & sampler 7 select : hot_cue 7
var '$sampler' ? sampler 8 play_stop & sampler 8 select : hot_cue 8
var '$sampler' ? sampler 9 play_stop & sampler 9 select : loop_in & loop ? on : off
var '$sampler' ? sampler 10 play_stop & sampler 10 select : loop_out & loop ? get beatgrid : off
var '$sampler' ? sampler 11 play_stop & sampler 11 select : loop & loop ? get beatgrid : off
var '$sampler' ? sampler 12 play_stop & sampler 12 select : loop ? loop_exit & blink 300ms : off
Vestax VCI-400
shift button
geposted Tue 01 Oct 13 @ 2:18 am
var '$sampler' ? sampler # play_stop & sampler # select : var '$shift' ? delete_cue # : hot_cue #
but again, you are globally changing the pads to sampler mode, so you will be controlling samples on both the left and right side of the controller
geposted Tue 01 Oct 13 @ 2:44 am
uhm... will '$shift' ever be 1 in this query?
You set it to 1 while holding and then go to " : set '$shift' 0 " ....
Haven't tried the script, but that doesn't make sense to me.
geposted Tue 01 Oct 13 @ 5:30 am
Yes, it's a brilliant bit of script, what it does is when you press the button it will activate the shift, then depending on whether you hold the button for over or under half a second it will either deactivate the shift if released after half a second, or both deactivate the shift and toggle a secondary shift, so essentially you get two functions from the same button, you could even extend the hold time so you have a different option if you held it for longer than say 4 seconds, I'm not sure where it would be used but you could do it if you ever found a need for it.
geposted Tue 01 Oct 13 @ 5:40 am
Ah yes you are right. I forgot about the default param value of 500ms for the holding action.
geposted Tue 01 Oct 13 @ 6:11 am
oh dont worry im still gonna use the script we are trying to get right...but im gonna put this on a back up file just in case we don't have it by the time i go do my gigs this weekend.
geposted Tue 01 Oct 13 @ 7:13 am
Haven't read the other thread, so forgive me if i am leading u to a different path.
Here is what i would do. Use the same button to toggle between Sampler Mode and Hot Cue mode, and at the same time set &shift 1 while key is pressed.
So more or less something like that..
down ? set '$shift' 1 : toggle '$sampler' & set '$shift' 0
The action for one of those buttons would be ..
var '$sampler' ? sampler 1 play_stop : var '$shift' ? delete_cue 1 : hot_cue 1
PS. Didnt test it.
PS. Didnt test it.
geposted Tue 01 Oct 13 @ 8:05 am
ok working right. Synthetic im just backing this up for a quick goto until we get uor project right....thanks evrybody...i asked synth if we get this mapping done could we share it with the community...we will see.
geposted Tue 01 Oct 13 @ 8:53 am
