Has anyone noticed any advantage of a .zip for karaoke over the having the files separately? I would imagine there is some extra processing involved for the software to have to extract the from the zip before playing; but, was wondering what the majority here use.... Any thoughts?
geposted Wed 02 Oct 13 @ 10:40 am
The only advantage is a small reduction in disk space, but that's not normally an issue with the huge hard drives available nowadays.
geposted Wed 02 Oct 13 @ 11:23 am
For me, having it ZIP makes my search a lot better, cleaner, right on the spot.
Blurred Line zip will result in LESS clattered browser.
geposted Wed 02 Oct 13 @ 12:10 pm
This would only be the case if you are searching outside of VirtualDJ.
If you are browsing/searching within VirtualDJ using its browser/database, then it will only show each song once as a karaoke file, regardless of whether it's zipped or not.
geposted Wed 02 Oct 13 @ 1:02 pm
