I am using others MID program in the same computer and I got problem with the controller pitch, this appears get programming, I meam now it is change the pitch as ramdom all the time the pitch change by itself.
How can I fix it, I try to reset with the CONFIG-Mappers and restore default but it doesnt work, any ideia how to clean it?
geposted Thu 03 Oct 13 @ 8:17 pm
If the pitch changes each time you load a song in VirtualDJ, make sure that you have disabled the auto pitch matching and pitch reset options.
Please see our FAQ pages:
https://virtualdj.com/wiki/Disable%20Auto%20Pitch%20Matching.html
If the pitch keeps moving around by itself erratically, then it may be faulty or may need cleaning. Please see https://virtualdj.com/wiki/Button%20on%20MIDI%20controller%20does%20not%20always%20respond.html
geposted Fri 04 Oct 13 @ 5:24 am
