hello please help me
ive got vdj pro and sereto scratch timecodes i want to use them with the n4 but i cant get it to work.
could someone please help me out with step by step instructions.
im having probs with the soundcard asio keeps saying not enough channels and the settings for input/output
cheers
cheers
geposted Sun 06 Oct 13 @ 5:12 am
ive managed to get sound coming out from the deck. but its like the numark n4 is not connected to vdj. ive got no crossfader or channels. what settings do i need.
cheers
cheers
geposted Sun 06 Oct 13 @ 8:54 am
since you don't have a license to own you should contact support
geposted Sun 06 Oct 13 @ 9:18 am
Be sure to have your channels assigned to PC instead of line (in front of the N4) and at the back the switch next to your usb port should be on timecode (not on usb recording).
Also if U use vinyl for timecode be sure to attach the ground cable of the turntable to the N4 for clearer sound.
And you need VDJ Pro to be able to use the timcode capabilities of the N4.
In the conifg panel in VDJ Pro, you should put the input to timecode. (if you're on Windows, it may be possible you have to use ASIO4ALL to arrange the output)
Lastly, you can tweak the settings for timecode in the settings menu after you assigned the input as such.
geposted Mon 07 Oct 13 @ 5:50 am
Hallo leute benötige mal hilfe also ich habe 2 dj tech turntables 2 traktor vinyl s und als mixer dient meine hercules rmx !
Jetzt zum problem also ich habe alles angeschlossen es kommt auch ein ton nur viel zu schnell und das signal ist kaum mehr als 6 % auf beiden
Bitte bitte ich brauch hilfe
geposted Fri 01 Nov 13 @ 7:11 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the correct language forum: https://virtualdj.com/forums/6/German_Forum.html
geposted Fri 01 Nov 13 @ 7:32 am
