In Option what is the Set ?? and to Performances like Latency! What is the Best Set up in Scratching. :)) Help me Please
geposted Mon 07 Oct 13 @ 12:19 pm
Please help me!
geposted Wed 09 Oct 13 @ 4:13 am
you need VDJ Pro, then you can use the registry tool to lower the "default scratch latency" which will tighten up the software's response to scratching. Also your crossfader should be set to "scratch" in the config --> options menu.
Finally you need to realize that good scratching is not dependent on how low the latency of your jog is or how many ticks per revolution it is. The primary way to do good scratching is to have good technique.. The rest of the stuff people say is just excuses. A great source of learning technique is dj Angelo on youtube.
geposted Wed 09 Oct 13 @ 4:57 am
The best setting depends on your computer and its performance. Set the latency as low as you can go without getting sound break-up, distortion, etc.
Make sure that you have also optimised your computer for DJ performance: https://virtualdj.com/wiki/Performance%20Issues.html
NOTE: Configuration options are limited in VirtualDJ LE. If your controller came with VirtualDJ LE then you can optionally upgrade to the full Pro at a discount by going to https://virtualdj.com/buy/ - Otherwise you will need to purchase the full VirtualDJ Professional to be able to use it with VirtualDJ. If you like VirtualDJ, then please support the software and its future development by purchasing it (Especially if you are a working DJ and you are making money as a result of using it at your gigs.)
geposted Wed 09 Oct 13 @ 7:04 am
