my issue is after playing for 30mn or so no sound comes out the right channel everything looks normal but no sound in head phones or speaker left channel works fine., my only fix is to reboot then it happens again. all drivers are up to date and no virus.
any suggestions?
windows 7 PC
any suggestions?
windows 7 PC
geposted Wed 09 Oct 13 @ 12:50 pm
Try these..
- Make sure the VMS2 is not the default Sound Device in Windows (Rightclick on the speaker icon on bottom Taskbar-->Playback devices)
- Disable (from Device Manager) any Bluetooth or wireless device you may have.
Post here a screenshot of your VirtualDJ Sound Setup (Config-->First tab)
geposted Wed 09 Oct 13 @ 2:18 pm
Make also shure, that any usb and harddrive energy saving options are disabled.
Do you use a wireless mouse..?
geposted Thu 10 Oct 13 @ 3:03 am
