Not sure if this has been covered before but I am looking for the best place to get a DJ drop made either free or pretty reasonable
Any suggestion?
Or maybe point me in the right direction to where I can make my own
Thanks in advance for the help
Any suggestion?
geposted Fri 11 Oct 13 @ 5:08 pm
I like... http://www.yourdjdrops.com/ for mp3 & mp4 drops.
geposted Fri 11 Oct 13 @ 6:29 pm
Those Drops are Official. I got mine years ago when the website was Called Your remix. Now they teamed up with The Hot 97 guy.
geposted Fri 11 Oct 13 @ 8:51 pm
Try the Wigman http://www.djdropsbywigman.com/.
Cheers,
Roy
Cheers,
Roy
geposted Sat 12 Oct 13 @ 9:08 am
i now use Jay over at > > > http://customdjdrops.com/
awesome job, and seems to go the extra bit to "Personalise" your drops, rather than just drop your name over pre-written fx and such..
also supplies you with the original "Dry Voice Only", so you can, if you wish.. chop and change, creating extras.. ;-)
geposted Sat 12 Oct 13 @ 9:37 am
Haha I got some from wigman. He literally sounds the same when he talks on the phone, I thought it was a joke at first. They are expensive though. If you use any producing program just record a friends voice and edit your drop from there....save you some $$
geposted Sat 12 Oct 13 @ 12:30 pm
Not everyone has the voice to make a Good dj drop. Many sound cheezy.
geposted Sat 12 Oct 13 @ 1:34 pm
Thanks I appreciate it I'll give some of those a try
geposted Sun 13 Oct 13 @ 11:25 am
I use http://www.djdropsbywigman.com/ a lot ..
He is a member on site here, and on vdj radio too (used by lots of the djs there).
Fast delivery, top quality, and never had any bad experience with this guy .. .
geposted Mon 14 Oct 13 @ 9:19 am
