Hey guys I was just wondering if there's a way to have the track on my second deck automatically start playing once a certain time is hit on the first deck? I'm trying to match a beat on these two tracks but I can't get it perfectly without having to sync.
Thanks!
Thanks!
geposted Sat 12 Oct 13 @ 9:44 pm
Good Question, I've got to try that myself.
geposted Sun 13 Oct 13 @ 5:26 am
Thanks!
Thanks!
The rest of us simply practice and practice and practice... once we think we figured it out, WE KEEP PRACTISING!
geposted Sun 13 Oct 13 @ 12:20 pm
Yes, learning to DJ manually is way more useful than relying on any automatic features.
Bear in mind that if one (or both) of your two tracks varies in tempo while it's playing, then using sync or some auto cue/start feature will never keep them in time. You either have to learn to adjust the pitch control on the fly, or use some software to correct the timing of the track(s).
geposted Sun 13 Oct 13 @ 12:37 pm
Either learn how to beatmix manually or use automix. Don't attempt any stunts, live, if you haven't mastered them yet.
geposted Mon 14 Oct 13 @ 1:28 am
[quote=JamiePatrick I'm trying to match a beat on these two tracks but I can't get it perfectly without having to sync.
Thanks!
[/quote]
You could 'program it' to start on a certain point.
But I'm absolutely sure you'll be far happier in the end if you practice and learn the way to do it as a DJ.
After all, if you just want to 'program' a mix, you might just use the auto mix function of VDJ.
Thanks!
[/quote]
geposted Mon 14 Oct 13 @ 9:17 am
