how would you call or map an effect that's in a folder the user created
geposted Sun 13 Oct 13 @ 12:28 pm
you just need to add the filepath from the sound effects folder... Not sure if it matters whether you use a backward or forward slash, but try them both. Also not sure if it will work in home or LE
effect "folderName/effectName" active
geposted Sun 13 Oct 13 @ 12:58 pm
it works, Thanks
geposted Sun 13 Oct 13 @ 1:04 pm
Are you using a pc or mac?
geposted Thu 16 Jan 14 @ 8:15 am
