Hi guys i made multiple decks skin like first 2 decks appears by click of a button 4 decks appears deck layout is 3,1,2,4
the problem is in 2 decks layout for both deck 1 & 2 the %Ppitch stays +0.0 even when the pitch slider is being manually changed
and in 4 decks layout deck 1 remain time shows but not working the way it should there's only remain text which is overlaped by button to
blink at to stage but blink is working text doesn't show when that button is moved text shows then button is overlaped on other text
here's a twist first i did deck 3 all script for this deck is working fine then i copied the same script for deck 1,2,4
now the deck 1 ,4 has the upper stated problems in 4 decks layout
and there's a part of element from 2 deck layout from deck 1 2 is visible in 4 deck layout when i hover over it disappears
next is the browser section
when i start virtual dj skin loads up or the preferred skin is changed the browser stays blank untill i click on browser area
i hope you understand what i meant
i will post a video link regarding all this problem in next post due to my current internet speed
thank you.
thank you.
geposted Thu 17 Oct 13 @ 10:55 am
