I have just got a mixtrack quad and am using the supplied LE edition (currently using the 20 day Pro trial). Occasionally the shift button on my deck seems to become the opposite - (as in it is always on and pressing it turns it off). Im pretty sure the buttons on the mixtrack are fine as they work fine on the other three decks on the program. Have I inadvertantly done some sort of key combo that has reversed the shift key? If i restart the program it all goes back to normal. It happened to me last night on deck one so i layered down onto deck three and it is fine. I cannot work it out.
geposted Sun 20 Oct 13 @ 8:49 am
